Any Ideas on a good kit cutter
Reply
Old 07-07-2007, 10:14 PM
jetranger-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Any Ideas on a good kit cutter
I have a set of Jerry Barrons plans for the Hawk P-6E 1/4 scale. The problem is the way the the ribs are cut,it is very easy to wreck the ribs when cutting before you finish cutting it. The ribs have a D like hole in them and the spar slides throuh then rotates to lock in with a notch cut in the spar top and bottom to hold the rib. Way too much work to cut and 90 some ribs and only two the same in each wing.
jetranger-RCU is offline
Old 07-07-2007, 10:29 PM
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Any Ideas on a good kit cutter
Give Larry Katona at Precision Cut Kits a call.
Seems like all that cutting is just part of the appeal of plans building.
khodges is offline
Old 07-08-2007, 12:42 PM
jetranger-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
khodges
I like building from plans but these ribs are a night mare to cut. Where the spar goes, there is only one in the wing, through the ribs. It starts off as 1/4 inch by 1 1/2 ply and tappers to 1/4 at the tip. There is only 1/8 inch of rib on the top and bottom of the hole that is cut in each rib for the spar. And thus one slip you break the rib. Kind of hard to explain, but seeing the plan would show what I mean. I hope they could either cut as plan or change to top and bottom spars. By the way the plans are blue print kind. Also ribs are shown full size laying on the wing plan from center to tip with bottom of rib lined up where it build from. I built a lot of 1/4 scale and up but this one I love the plane , but I don't want to do all that cutting
