Ailevator--what is it?
My Feedback: (20)
OH
My 7c Futaba radio manual mentions Ailevators as a mix I can program in. What does this function move on an airplane and how can it be used beneficially in flight or 3-d?
My Feedback: (20)
PA
RE: Ailevator--what is it?
It is used to control both ailerons and elevator on something such as a flying wing where there is not a separate elevator and aileron. I dont know the answer to your other question.
My Feedback: (8)
The best example of the use of "ailevator" is the Avonds F-15. It is originally designed without any wing control surfaces and no rudders. The horizontal stabs function as both elevators and ailerons. The plane is surprisingly maneuverable with this type setup.
Sometimes this setup is also referred to as "tailerons" and also sometimes as "elevons".
GA
another option is that the ailevator mix is used if you are using two seperate servos for the elevator.....
plug the servos into 2 seprate channels, turn on the ailevator mix, dial the aileron portion to 0 percent and set the elevator portion so your elevator halves travel together....
My Feedback: (20)
OH
ORIGINAL: exeter_acres
Alleviators (ailerons and elevator mixed) is pretty much the same as another term, elevons (elevator and ailerons mixed) It is a mixing of control surfaces that can control movement around 2 axes 'pitch and roll' for most uses or depending on the configuration of the actual control surfaces. But generally in rc its just for pitch and roll. This is used in some models to simplify controls for example on a combat plane with no empennage (tale surfaces), to proved roll as well as pitch the control surfaces on the trailing edge of the wing would have to operate in sequence with each other to provide the correct roll and pitch input from the pilot. On other planes, for example ones with an empennage could also have this mixing function on the trialing edge of both the main wings and the horizontal stabs to simply provide more control response in the affected axes.
