Thrust, power, and RPM's?
Do I get more 'power' with a bigger prop turning fewer rpm's, or a smaller prop turning higher rpm's? So, I hopped up my old Saito 45 MK2 with a 50/56 size cam. Ran a new ring in with a 12/4 prop. I could get down to 17-1800 rpm's and up to 12k + using the Master Airscrew prop. I seemed to have problems getting it started and had to use the electric starter. I looked around for a 12 APC thinking a heavier prop might help. Didn't have one, but found a big 13" 'Dynathrust', thought I'll give it a try. I can back flip that thing once or twice, and off she goes. Will sit there and tick over so quiet! But, I can only get her up to about 7500 rpm's. BTW, I have it running inverted in a Bird Dog, so speed is not the issue here. What am I gaining or losing with the prop size/rpm factor, is there a mathematical answer to this? I'll add, I run a big 22" Dynathrust prop on my ST G4500 and it's the same, easy starting with a back flip-it just seems to like a big ole heavy timber! Bill
RE: Thrust, power, and RPM's?
"Power" is not definable unless you have a dyno. Generally larger diameter/Low pitched props that have the same load factor will pull harder but at the cost of reduced airspeed.
The mathematical formula for thrust is: Thrust = 2.83E-12 x RPM^2 x D^4
What is the pitch on your 13" prop. Someone can then calculate approximate thrust and speed calculations.
For example...ThrustHP puts out these speed figures:
Prop Selector from http://www.gylesaero.com/_frames/f_propcalc.shtml]Gyles AeroDesign Propeller Calculator puts out the thrust measurements:
12-4 @ 12,000rpm = 45.46 MPH and 6.1 lbs of static thrust
13-4 @ 12,000rpm = 45.46 MPH and 8.03 lbs of static thrust
13-4 @ 7500rpm = 28.41 MPH and 3.14 lbs of static thrust
13-6 @ 7500rpm = 42.61 MPH and 4.02 lbs of static thrust
13-8 @ 7500rpm = 56.82 MPH and 4.87 lbs of static thrust
Actual Prop brand and type will change these figures substantially.
Thanks, very interesting data. The static thrust variation between the pitch values is especially noteworthy. I'll have to pull the prop off tomorrow and check the pitch. I will probably experiment with a few more props. Normally, I would just overpower something, but here I'm trying to save a scale appearance without a head cut through the cowl. The engine is marginal for the plane so i want the most 'power' to get it off the ground, but want slower, scale like flight.
Here is a bit more info on your engine. http://www.rcuniverse.com/forum/m_42665/tm.htm
It looks like a 12-4 is probably your best prop. However, I would replace the Master Airscrew with wood or an APC. The MS props are loaded pretty lightly for their pitch.
