Goldberg Ultimate Biplane CG location
I flew one of these. Personally I had nothing but trouble with this airplane. I don't have the plans anymore however, I thought that I would give this warning that I experienced. If your engine stalls in flight, make sure that you have plenty of altitude. The parasitic drag on this beast is awful. The engine that I had every now and then would die in the air. Then the plane just stops flying then it rolls to the left or right and you know whats happens next. Be sure to land with power. Hope this helps.
My Feedback: (67)
Kevin,
I have one of these and will check my plans this evening for you. I have not had any problems, but with this one and the last one i had, as mentioned by macmaster, you need to keep the speed up for landings. if you do it will grease in very nicely....don't try to flare and slow it down too too much.
My Feedback: (41)
CG
I would appreciate it if you would post the CG or e-mail me. This is my second one I've owned in about 12 years. I am trying to get the optimum CG setting without moving it back too far from the manufacturers suggested location. I love this plane! Contrary to what I used to think this plane will 3D very well! I have been doing high alpha harriers about 2 feet off of the ground and it is stable as a rock! It will also hover very nice and do a nice elevator. I am learning torque rolls with it but so far have only been able to get about 1 1/2 rotations out of it. Anyway, thanks for your help!
KEvIN
KEvIN
My Feedback: (67)
Kevin,
All I can offer is the manufacture's recommended location...which is a range of 1", from the firewall it's 7.75"-8.75" back and from the leading edge of the bottom wing it's 2"-3".
I'm afraid I don't do any 3-D with the plane, and only fly it on a ST90.
