how do you make diesel fuel
RE: how do you make diesel fuel
check with davis diesel they used to have a concentrate that you added diesel to.Iknow most of the ingredients are eyther(highly flammable) oil and I think amyl nitrate.
PA
See Joe Wagner's column in the January, 2002 issue of Model Aviation for a formula using ingredients available from WalMart.
1 part Kero, 1part Oil, 1 part Eyther. Basic mix and will work well. Getting the "Eyther" will be the problem as it is highly explosive.
Cheers
Cheers
