Fuel question
CA
Fuel question
I have been told by another flier that he uses 2 stroke fuel in his 4 stroke engines. Is this a good idea? What is the differance in the 2 vs 4 stroke fuels?
Thanx WSL
Thanx WSL
RE: Fuel question
Like John just said, some 4stroke fuel has less oil content.
4strokes can often get by with lots less oil than 2strokes. So it'll be worthwhile if you ever think about using some 4Cycle fuel in a 2C to look closely at the ingredient percentages.
I saw one jug of 4C fuel some years ago that had a sticker on it that said, "For 4-cycle only". (But it had gotten oily and was about to fall off. So don't bet on being warned about the low oil content stuff with any labels.)
RE: Fuel question
I don't pay any attention to 2/4 stroke designations. If you talk to the various fuel manufacturers, you will get a wide range of theories for what 2 and 4 stroke fuel is. It will become quite clear that it is not quite clear! Fuel is made up of methanol, nitro and oil at various percentages of each. The oil may be castor (not very common anymore), synthetic, or a blend of the two. Use what is appropriate for your engine. The general trend is to stay away from castor (or blends) in 4 strokes because it tends to carbon up the valves. I run 15% nitro, 18% synthetic in all of my engines, 2 and 4 stroke alike. Just make sure you tune your engine correctly (not too lean). I have read that synthetics are less tolerant to lean runs than castor (blends), but have not experienced it myself because of diligent tuning.
Mike
Mike
SC
RE: Fuel question
Be sure to run fuel with a synthetic/castor oil mix in ABC/N engines. Ringed engines can use total synthetic and lapped (are there any still out there?) engines need more castor.
Dr.1
Dr.1
RE: Fuel question
You may be able to ignore the designations, or the name of the fuel, but don't ignore the ingredient percentages marked on the jug. It they're not there, don't use fuel that says it's 4cycle in a 2cycle. Two stokers need at least 18% lube.
And there has been and probably still is fuel labeled 4cycle that contains lots less than 18% lube.
RE: Fuel question
ORIGINAL: da Rock
Mike
NC
RE: Fuel question
I've been running cool power 15% in my .46ax's. I have a gallon of 20/20 fuel (pink) that I was experimenting mixing with gas for a gas engine. Decided not to use it. Is it OK to run this in my .46's and then go back to 15%? They have both been broken in and run on 15% since they were new (about a year old).
