Engine mount and nose gear mount Q
SC
I bought an H9 Advance 40 with an Evolution 61. This is a new plane for me. The maiden went very well except for the landing. She had a flimsy two bolt nose gear mount on it that allowed a fair amount of play in the gear itself. I did some work and tightened it up, but I never shoulda put it in the air. Never the less, I poked out my firewall and caused general carnage when she hit a tree on the rollout. Dumb.
I replaced the firewall and have a new engine mount and two different style nose gear mounts. I guess I want someone to pat me on the head and give me the OK.
The new two bolt nose gear mount has me a little concerned. I don't want the floppy gear like I had before. The four bolt mount is off my trainer (RIP) and always proved a very solid mount. The four bolt however is in the way of my engine mount. So.......?
1) Use the engine mount as-is with the two bolt nose gear mount?
2) Use the four bolt nose gear mount and cut the bottom of the engine mount to fit and relocate it's holes?
As you can see, the engine and four bolt nose gear mount won't both fit on the firewall even if I move the engine up, which I'm not even sure what that would do.
And I should mention that the engine mount has a flat on the bottom to support the nose gear.
Thanks for the input.
RE: Engine mount and nose gear mount Q
instead of pat on head, consider a combination engine mount and nose gear mount. Lots of sizes and shapes.
http://www3.towerhobbies.com/cgi-bin...=RF&search3=Go
The adjustable engine mounts are questionable. When the mount is opened up for wider engines the wire hole is not in the middle.
The real solution here is to drill a hole right through the engine mount to take the wire. Get rid of the nylon clamp. The problem is that ARF's being the cheap things they are, the nosegear wire is probably not long enough at the top end to go through the mount. So you will probably have to purchase another one of those from a hobby store,
Ed S
Ed S
SC
ORIGINAL: Ed Smith
Ed S
Ed S
Thanks for the info.... I think that's exactly what I'm going to do.
SC
ORIGINAL: scratchonly
You can use the engine mount hole AND the 2 hole mount.
Yea, that's how I read it the first time, but now that I look at it, I don't think that's what Ed Smith said though.
I am going to use the two hole mount and drill the engine mount to accept the gear wire.
Thanks all, been a big help!
SC
Alright last question,
The mounts come with a wood screw to bolt it on the firewall. This would be easier, but I'm kinda cautious of using the wood screw. Generally I use a machine screw and t-nut. Any opinions?
Do not use wood screws. Use socket head cap screws and Tee Nuts.
Ed S
Nose gear is a pain. You can also drill only part-way onto the engine mount and use it as an upper bearing with the two-hole Nylon retainer below it.
