Reload this Page >
mixing aileron and rudder ratio on hanger 9 pts p-51?
Old 10-16-2007, 11:09 PM
flyrcguy
Banned
Default mixing aileron and rudder ratio on hanger 9 pts p-51?
i have a futaba t6xas i want to mix the servos on the ailerons and rudder.This is the hanger 9 p-51 pts .
Old 10-17-2007, 04:11 AM
jetmech05
Default RE: mixing aileron and rudder ratio on hanger 9 pts p-51?
are you a beginner?
Old 10-17-2007, 11:34 AM
flyrcguy
Banned
no this is my 3rd plane and before anyone says use both thumbs i prefer mixing .
Old 10-17-2007, 12:17 PM
Charlie P.
Charlie P.'s Avatar
Is your purpose just level turns? Go into "Advance Menu" and highlight an unused mix. Switch "INH" to "ON" for that mix. Assign aileron as master (MAS) and aileron as slave (SLV) and then assign it to an unused switch so you don't have it messing up other maneuvers. Switch the Link to "ON" and then set the switch position. Then assign a % of mix . . . maybe + and - 10% should be plenty but you'll have to experiment to see what works. I don't have a 6TXAS but those are the steps for my 9C. The logic flow may be the same.
Read the book that came with the radio. ;-)
