What size tank
GA
What size tank
I am going to get a Sullivan Skywriter smoke pump for my Ultimate Bipe and wasn't sure on how big of a tank I would need for the smoke fluid. I obviously want to add as little weight as possible but then again don't want to run out of smoke fluid mid-flight.
Any ideas?
Any ideas?
My Feedback: (20)
RE: What size tank
Which Ultimate Bipe are you flying? I put a smoke system on a Goldberg Ultimate with an OS 120 and took it out as it added a lot of extra weight affecting the flying characteristics.
RE: What size tank
Never don esmoke on a 2-stroke but it usually runs 3 to 6 ounces per minute on small gassers. You're blowing oil through a 1/8" hose with no carb or venturi to restrict. Runs out pretty fast.
RE: What size tank
I have a 14 oz tank on my Waco, pumping through a G-26. With really good smoke, it would last about three minutes or a little more. Don't know for sure what that translates to in a glow engine, but your 1.80 is greater displacement; it's the exhaust heat that makes the difference, though. For a tank that size, you'll have to worry about c/g shift from full to empty, unless you can mount it on the c/g. Also consider mixing the pump channel to the throttle channel, to increase smoke oil flow with increase in throttle. this way you can optimize the flow for best time and thickest smoke.
Three minutes doesn't sound like much, but you're not gonna leave it on the whole time. You should be able to put on a good show with 3 minutes of smoke.
RE: What size tank
The Seagull Ultimate has a cut out in the fuse right at the CG. I use a 14 oz tank and I tightened a bread tie around the tubing to somewhat restrict the flow. I've seen other guys drill out a 6-32 screw and use it as a splice / choke.
