Herr P-51 dihedral??????
I bought a 1/2A Herr P-51 Mustang kit and was reading through the plans.
The dihedral called for in the plans is 4 inches!!
Basically it makes the whole thing look a bit silly and wanted to know if I cut the dihedral down to half, what kind of effect would it have on performance/handling.
The wing span is 42 inches.
Thanks in advance.
Thanks in advance.
RE: Herr P-51 dihedral??????
4 inches total. 2 inches on each side. If you were to put one edge against the edge of your workbench, the other wing would be 4 inches from the edge.
ORIGINAL: Krener
... if I cut the dihedral down to half, what kind of effect would it have on performance/handling.
Thanks in advance.
Thanks in advance.
and then follows a stall and might crash. It is the position of the Center of Gravity which should
be maintained in vertical below or at least on the level of the wing tips.
