Stick 60 Landing Gear Issues
My Feedback: (40)
My stick 60 with .61 OS FX and 12x6 prop is a great flyer, but I have major issues with the front landing strut.
Engine is mounted on a .60 - .90 GP Nylon Mount which has the holes for strut molded in it. I have used Fults double which flexed so badly on landing that it broke the mount and punched a hole in the bottom. Presently I am using a 5/32" single with 4 coils, and the problem is too much flex once again. As you can imagine I need about 6" of strut below the the motor mount in order to swing a 12x6 prop. Plane weighs approximately 9 pounds loaded with a 92" wingspan.
Question: I am planning to increase the wire size to .187" or .203" while maintaining 4 coils, but I have no idea where to buy these - any suggestions? Also - since I will be reaming the molded strut holes - any suggestions on how to re-enforce them?
