contest balsa sources
CA
RE: contest balsa sources
hey Aerowolf, of topic but do you still need those citabria plans? I havent got any responce and its ready to go out, let me know, thanks Andy
WA
HOW LIGHT IS KILN DRIED BALSA WOOD?
Finished balsa wood, like you find in model airplane kits, varies widely in weight. Balsa is occasionally found weighing as little as 4 lbs. per cu. ft. On the other hand, you can also find balsa which will weigh 24 lbs or more per cu. ft. However, the general run of commercial balsa for model airplanes will weigh between 6 and 18 pounds per cu. ft. Eight to twelve pound balsa is considered medium or average weight, and is the most plentiful. Six pound or less is considered "contest grade", which is very rare and sometimes even impossible to obtain.
somegeek
