Aileron Twist
RE: Aileron Twist
G'day Mate,
I would not worry about that, alignment can be done when covering, hard to tell how far out it is, from the pic, but if you need to fix it, wet it with cloudy amonia, clamp straight & let dry overnight, it will not warp like balsa does when wetted with water.
RE: Aileron Twist
Use the ammonia and water method, about 50-50, and get the wood pretty wet. Apply an opposite twist, secure, and let dry completely. It's a trail and error thing. If you don't get all of it out then the balance can be removed with the covering and a hot iron. If you incur too much reverse twist you maay have to start over going the other way.
