2-56 wire diameter
2-56 wire diameter
i'm trying to thread some .072 wire with a 2-56 die. the wire is threaded on one end and i need to shorten the wire and re-thread the other end. however when i do this the threads are to thin in diameter and the clevis will just pull out. is this the correct diameter (.072 ) for the 2-56 threads? even though the wire is threaded correctly with the factory threads i am having no luck trying to do the other end. i have tried to adjust the die with no luck....
thanks
thanks
VA
RE: 2-56 wire diameter
It won't work I miked a 2-56 rod & it's .072 but the threads are .081 OD . The threads are what is called roll theaded & instead of cutting the threads it squishes them up from the basic wire size U need to start with a larger wire to cut threads in it.
Have fun
Bill Teller
Have fun
Bill Teller
G"day Mate,
As Bill said it won't work, that's why Dubro make threaded couplers, cut wire to length, solder on threaded coupler & screw clevis or ball link on to coupler & away you go.
Dubro Part # 212, see here, http://www.shopatron.com/product/part_number=212/101.0
ok that all makes sense now...........i have to look for a larger wire diameter if that's the way i want to go. or get the solder clevises or threaded ends.
Bicycle spokes are the correct diameter for threading 2-56 rods-picked up a junked bike at a collection site for $2 and robbed the spokes out of wheels-they are just right hardness and thread well, you are limited in length to spoke length, threads are 2-56 but wrong TPI. Also the brake cables make great throttle flex cables, they are more flexible than ones you buy. Now thats scrounging. Good Luck.
PA
Zobo2
From Unbrako, makers of high quality socket head cap screws, the body diameter for a #2-56 UNC is .086". But most of the time when you measure a #2-56 screw, it will be .002 to .005" under. This is true of almost all bolts including aircraft hardware like the AN series.
Gene
Gene
Be careful on the bicycle spokes, all are not the same diameter nor are they all the same thread. Also some are necked down after the thread and some are not.
thanks dave
i got all the info i need off that site...........i had the music wire..........thought it was to hard....lol looks like a good product too.....
My Feedback: (62)
NJ
The rodchuck seems to be the best solution, except that you can't use all of those scraps of rod left over in the shop.
I went with a carbon fiber tube.
It lets me use the 2/56 threaded, or the 4/40 unthreaded and threaded rod scraps.
Cut it to lenght and epoxy. Voila [X(]
Midwest #5721 is shown here on my OMP 80" Giant Scale Edge.
ID is 4mm(.157), and OD is 2.5mm(.098)
Here's a link --> [link=http://www.midwestproducts.com/item_detail.asp?item_id=443]Carbon Tube[/link]
The second picture is a section of the cf tube with an all threaded 4/40 rod in one end, which is tight going in,
and a piece of non threaded 4/40 rod in the tube, that has threads on the other.
I just have lots of these laying around, and it's handy for me.
Just epoxy and go!
I use it on everything, including my 35% stuff.
Good luck
Bob
Just epoxy and go!
Good luck
Bob
hey bob..............
that does seem like a good alternative, i'm gonna have to give that a try. lighter i'm sure but is the CF a lot more expensive?
