DX6 model selection problems!!!
WA
HI Guys,
Has anyone had problems with their DX6 and switching between helis and AC? I can progran ib 2 helis and switch back and forth between them, but when I try to program in an AC and then go back to a heli...it's reset to factory settings. The manual says I can store up to 10 models of helis OR AC. So far no help from Spectrum!
Dave
Dave
IA
RE: DX6 model selection problems!!!
Same exact problem the instructions dont help to come up with a solution anyone know anything any help would be greatly appreciated
WA
Hey Fossoman,
Just talked to Tracy and he's programming a dummy AC to "test". He also said he thinks you just get to the selection menu, then go to the model number, change that only and double click out. I'm at work, will try it tonight. He mentioned you had the same problem.
Dave
Dave
