Reload this Page >
Ultracote on fiberglass?
Old 01-12-2008, 11:58 AM
thomp896
Default Ultracote on fiberglass?
Will ultracote stick and stay stuck to fiberglass? I can't find a fuel-proof paint to match the dark blue(I think they call it midnight blue)ultracote. Rather than have the cowl not match the fuse I was thinking about just covering it with the ultracote. Any thoughts? Steve
Old 01-12-2008, 12:37 PM
Deadeye
Deadeye's Avatar
Default RE: Ultracote on fiberglass?
Model Airplane News used to have a tutorial, but they are now defunct. I did a Google for covering fiberglass with monokote, and got a few articles to read. I've never tried it with Ultracoat, but have covered fiberglass with monokote before. Base coat paint first, then just enough heat to get the monokote trim pieces down (not the vinyl, but regular monokote cut into trim stripes or whatever). The key is to avoid compound curves. After they Monokote is laid down, start by dusting your clear coat on. You should clear coat enough that the Monokote is totally encapsulated in the clear coat. The cowl and wheel pants on these two planes were done with that method.
You can also take a swatch of your covering to a good automotive paint store. They can scan it and even put it into a spray can complete with catalyst (use within 18 hours). This can be expensive, though.
ID:	849045   Click image for larger version
ID:	849046   Click image for larger version
ID:	849047   Click image for larger version
ID:	849048   Click image for larger version
ID:	849049   Click image for larger version
Old 01-12-2008, 01:31 PM
jaka
Hi!
Oracover (Ultracote) is much easier to use when covering a glassfiber fuselage than Monokote. Just sand the fuselage with 240 paper and go at it.
Old 01-13-2008, 12:05 AM
thomp896
thanks for the info guys, I'llsand it down and give it a whirl, if it doesn't hold I'll try the monokote method. thanks again, Steve
Old 01-13-2008, 02:01 AM
mikegordon10
mikegordon10's Avatar
Ya know that's funny 'bout what Deadeye said concerning MAN, considering I was just reading Feb's 2008 issue today. Me thinks he meant to say RC Modeler.
Old 01-13-2008, 11:49 AM
Deadeye
Deadeye's Avatar
ORIGINAL: mikegordon10
Right you are. I knew it was one of those glossy, ad-bloated rags.
Old 01-13-2008, 01:35 PM
mikegordon10
I'd have to agree with your opinion of MAN - RCM - Model Flyer etc. etc. The only reason I was reading a MAN was cause I was having a $5 cup of coffee at Barnes Nobel's Starbuck's with my wife. I have canceled my subscriptions to all the AD Rags and now get my reading fix with RC Report and of course the required Model Aviation.
Old 01-14-2008, 05:50 PM
JimO
My Feedback: (7)
Have you considered latex paint. take a piece of your covering to a good paint store and they can match it. Spray it on and let it sit for a week to cure and topcoat.
JimO
Old 01-14-2008, 07:51 PM
thomp896
what topcoat is fuel proof? I would like to paint the cowl if I can. Thanks Steve
