Weight scale
NY
Weight scale
This may be a basic question, but I cpould use some recommendations. Up to now I have always used an engine at the top of the recommended range for any plane I built. Now I am flirting with scale and matching engine to airframe gives me more options. I play exclusively in the .40 - .60 size league so I would like to find a good scale that will be reasonably accurate in the 4 to 10 pound range. Have already tried bathroom scales (With and without me on it) and a "good" fish scale. Neither gave accurate results in the range I work in. Any recommendations for a reasonably priced scale that will keep me happy?
FL
Weight scale
Take a look at this
http://www.oldwillknott.com/royrc40.html
I have one and it's great. They are sold at Staples, Office Depot, also.
FL
Weight scale
Scales are most accurate in the middle of their range. That's why a bathroom scale just doesn't cut it for the size models you're talking about.
Try to find a good baby scale.
Weight scale
In the kitchen gadet isle at Wally World they have a digital scale that does up to 5 pounds. It wieghs with grams or Lbs. You cabn weigh the wing then the fuse to get the total weight of the plane.
Dru.
Dru.
WY
Vote for Baby
I vote for the baby scale also. They are in the right range for you and you can get them cheap or free. Just check out garage sales, Goodwill, or friends who have two year olds.
The best part is the basket is great for holding the model.
NY
Weight Scale
Thanks for the responses. The baby scale bit sounds like a winner. The right range and, at my age, sure to cause some talk when I start shopping the garage sales.
Weight scale
I have a Columbis Family Scale with the date April 16, '07 on the dial. It is zero settable with a thumb screw on top and reads in one ounce increments up to 24 lbs. It has a 6" dial so it's pretty easy to estimate half ounce's between the lines. I think I paid $5 at a church bazzar.
FL
Weight scale
I bought my Escali digital postal scale off ebay about a year ago for $30 something. I've been very happy with it - runs off either a 9volt battery or included 110v adaptor.
It measures up to 25lb in 1/10 oz increments and also weighs in grams. Here's a link to their direct site:
http://www.digitalscalesdirect.com/
Mine is listed under "Postal Scales" (not Postage scales), and is nr. 25#-12k GREY Escali Scale + FREE 110V Adapter
Lynn
Lynn
My Feedback: (16)
Weight scale
THE BEST SCALE that I have found is a digital fish scale!! Before I used it I challenged it against some calibated weights at five reading from 0-50 lbs. The most it was off was 0.1 lbs. Will have to check on the name brand if you are interested. They were around $35-37.
NY
Weight scale
Thanks for all the inpts, guys. After careful (?) consideration, I sprung for the 25-pound postal scale from Digital Scales Direct. A little pricey for the use it will get, but I am happy with it on the first two models to get weighed out. Solid repeat readings (within an ounce). Thanks again. I'm off to weigh something else!
Rapala Digital Scale
I just happen to have one of these in my tackle box (That other hobby). They cost less than $ 20.00 usd It is a Rapala Digital Fish Scale and it works great for RC Planes and Salmon
Bob
Bob
