Need help quick Airtronics receiver
CO
Hi, can anyone tell me where the pos. neg. and signal go on this receiver. Everything I have seen said the black receivers from Airtronics is the old style, but I beleive this is the Z connector, right? Any help would be great, pics are a big help. Thank you.
Rob.
Rob.
RE: Need help quick Airtronics receiver
That is an old plug style Airtronics Rx. You cannot plug a Z plug into it the positive and negative leads are reversed.
Positive is the #3 pin the one to the side of the case in your photo.
Negative is the center pin
Sense is the #1 pin (toward the inside of the Rx.)
John
John
