top flite flat monokote
RE: top flite flat monokote
The only thing with flat monocote is the color is on the outside of the plastic not the under side, that way it can be flat.
ie- take a piece of scrap clear plastic canopy, spray one side with flat paint.
You will see from the side you did not spray it is shiney, the other side that you sprayed will of course be flat.
