carbon fiber rods and radio question
i should have asked this question before going this far, but it's done now so i will still ask.
in the picture you can see the .040" CF rods i used for diagonals in this Nieuport 11. they are lighter and much stronger than what is supplied in the kit.
they are anchored in holes drilled at each end, and are bonded together where they cross each other.
the radio i use is Futaba 2.4Ghz system.
do you think there will be any interference problem?
