os 61 carburetors
RE: os 61 carburetors
i've seen many carbs crossed over to other engines both from the same manufacturer and different manufacturers. the throat size has to be the same and the retaining method needs to be the same i would think.
david
david
CA
I emailed OS with this same question, and they said I was on my own, because the switch has not been tested by them. It appears the throat size is the same, but the 60C is twice as expensive as the 60J. I'm thinking it should work--maybe for the $25 you save it's worth the risk. Thanks for your reply!
tboyden
tboyden
