urgent help!!!
urgent help!!!
hello guys..,,
i wanted some help as i want order some stuff online as soon as possible!
1) would a 5 cell sanyo cp 2400 be enough on my 50cc gasser ( have 4 hitec 5985 and a 5995) or should i go for a redundancy setup with 2 sanyo cp 1700 batteries for my reciever?
2) what aluminium spinner do all use on a 50cc , 3.5" or 4"
3) i have a dl 50 , what size shaft adapter will it need to fit an aluminium spinner?
manyu
manyu
RE: urgent help!!!
1) Yes. But a redundancy setup is always better.
2) Depends on the plane's cowl, not the engine size.
3) Check engine manufacturer's website for engine specs.
My Feedback: (25)
RE: urgent help!!!
1. You'd be better off with a Fromeco Li-Ion or LiFe (A123) IMAC package for 28-30% planes. You will not need a redundant set up with that. Click here for the information: [link=http://www.fromeco.org/]Fromeco Scale Avionics LLC[/link]
2. Spinner depends on the plane...what are you putting it on?
3. The DL 50 prop shaft is center drilled and threaded for your spinner bolt. No need for a spinner adaptor.
Take care,
Jon
Take care,
Jon
