9CAP throttle servo reversing...
AB, CANADA
Looking through the manual my new radio and it says that when you reverse the throttle servo, the trim setting also reverses and that it changes the setting for all the planes?!? Is there another way to keep the servo reversed for an individual plane or do I have to use another channel so that aal the planes aren't affected? Thankx for the feedback. [8D]
RE: 9CAP throttle servo reversing...
ORIGINAL: Fastsky
ORIGINAL: daveopam
Something is not right there. I have 8 models on my 9C. It has never reversed the trim.
David
David
AB, CANADA
I am looking at Pg. 31 where it says "THR-REV is a special function that reverses the entire htrottle control." 2 lines later it says "This change affects all models in the radio." IS this a seperate item from just reversing the throttle servo??
ORIGINAL: Fastsky
To simply reverse your throttle, go into REVERSE, and select #3.
