doubts about planes specs.
Dear friends,
I have read in airplanes specs about fuselage lenght,
It means from tip of spinner to end of rudder?
I have read too obout wingspan,
It means span with wings mounted on the airplane?, remember
that some planes have the wings in two pieces, so the center
of the wings it`s the fuselage.
somebody could help me?
thanks a lot,
Carlos Muñoz
thanks a lot,
Carlos Muñoz
That's a good question concerning fuselage length. I never really thought about it. My guess would be from the cowl or front of the engine's thrust washer to the back of the vertical or horizontal stabilizer (not including the rudder or elevator), whichever was longer. I do not think the spinner would be included. There are some very different design variations that would challange this ( A Japanese Zero, for instance, has fuselage extending even beyond the rudder).
Wingspan is easier (I think??) and would be wingtip to wingtip fully assembled. Multi-winged aircraft would count only the farthest extremes, not the total of spans.
I can start naming off planes that would disobey these simple guidelines. (FE2 Gunbus Pusher, most multi-engined planes, exposed engine planes like Stiks,
Any Aeronautical Engineers out there with definative answers?
Doubts about airplane specs
Hi CHarly P.,
thanks for your reply ¡ ¡ ¡
I take a Edge 540 picture from the internet and scale it to bring 64 inches wing span and the fuselage in the picture shows 54 inches lenght from top of cowling to end of rudder.
I`d like to know what do you think about this.
Carlos Muñoz.
Carlos Muñoz.
It's when you get to WING AREA that you don't count the fuse.
Thanks MR. Pinball,
The fact it`s that I am going to build an airplane taking it from a picture. The airplane specs are 64 wingspan and 59 inches fuselage lenght. When I did scale the picture I assume that 64 inches wingspan would be wingtip to wing tip so the fuselage lenght at the picture is 59 inches from the tip of cowlin to the end of rudder.
Some people says that rudder doesn`t count, but rudder in the picture is 6 inches.
Thanks for hearing me.
Carlos Muñoz
Carlos Muñoz
