tower kote?
Reply
Old 04-09-2008, 02:27 PM
newbe ray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default tower kote?
hello
has anyone ever tryed tower kote to cover a plane?
newbe ray is offline
Old 04-09-2008, 02:36 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: tower kote?
I used it to cover part of the wing when I repaired a trainer. It is low temerature covering and it doesn't shrink a lot. My patch job looked "OK" and stayed on about as well as the original ARF covering. I have read that it is not fuel proof and that oil will seep under the seams and make it come off.
People sometimes use this, and Econokote, to cover foam wings that cannot handle high temperature covering. Combat guys use it. Those wings usually get detroyed quickly enough that they don't have to worry whether it's really fuel proof.
carrellh is offline
Old 04-09-2008, 02:40 PM
newbe ray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well that don`t sound good[&o]
Old 04-09-2008, 03:14 PM
r2champion
r2champion's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The actual covering is fuel proof. The trouble lies in the fact that it doesn't adhere to the balsa as well as other plastic coverings, leaving the opportunity for edges to lift allowing fuel underneath. If applied correctly with all seams facing against the airflow, fuel soaking will not be an issue. It is similiar to econokote and is applied at a lower temperature. It is suprisingly easy to work around corners and curves. The only downfall I can see, is that it is noticably thinner than others and will tear if you pull too hard when applying.
r2champion is offline
Old 04-09-2008, 03:42 PM
mfracer@itctel.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A coat of Coverite Balsarite before covering & you shouldn't have too many problems.
I actually use Coverite Balsarite before any brand of covering.
Mike
mfracer@itctel.com is offline
Old 04-09-2008, 05:14 PM
newbe ray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ya mike i have some coverite i was going to fuel proof some parts with (three coats) ,but you say do all of the plane?
Old 04-09-2008, 06:17 PM
RCPAUL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Towerkote adhesive is not fuel proof! With direct contact with fuel, the seams will lift.
Paul
RCPAUL is offline
Old 04-09-2008, 08:56 PM
mfracer@itctel.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The balsarite was never said to be fuel proof or make anything fuel proof.
It does however allow covering to stick so much better than not using it.
I apply it to any part of plane that will have covering applied to it.
I only use 1 coat.
P.S. I have used all brands of covering & never had any problems.
Must be preparation.
Mike
Old 04-10-2008, 06:07 AM
newbe ray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well on the can of coverite it says it can be used to fuel proof with 2-3 coats..
is this not wright?
Old 04-10-2008, 07:57 AM
mfracer@itctel.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey,
My can says the same thing.
Another Bonus!!!
Mike
Old 04-10-2008, 08:25 AM
newbe ray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
great, guess i did not get the only one hehe...
Old 04-10-2008, 05:43 PM
rctrax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used towerkote in the past and found that it worked pretty good. My observation was it turned brittle quite soon and was prone to split.
rctrax is offline
Old 04-11-2008, 11:07 AM
JRFisher
JRFisher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have Towercote on all my planes and have had no problem with it at all.
JRFisher is offline
Old 04-11-2008, 11:54 AM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Towerkote is an Econokote "2nd". It is thinner than Monokote and although it is a low temp film, it tends to get brittle quickly. The adhesive is of marginal quality and if you decide to paint the airframe with Balsarite or SIG StixIt for proper adhesion, any weight savings will be lost.
For planes with a short life expectancy (combat planes) it is probably a good choice.
For planes you want to keep awhile I suggest a decent covering. If you want/need low heat use Ultracote, if you need a fabric go with SolarTex (or any of the "Tex" coverings). If you need a super lightweight covering (.6 oz per sq yd, that is point 6 oz !! ) use Solarfilm or Micafilm. Be aware that neither of the super lightweight films are fuel proof and due to the inherent static electricity, can be "interesting" to apply.
Campy is offline
