72 Saito on Pulse XT???
Hey all.
I''m not having much luck in squeezing my 72 Saito onto the firewall of my Hangar 9 Pulse XT.
The problem is the throttle arm is sticking out in the middle of nowhere, and I''m naffed if I know how to connect this to work.
This is only a temporary thing to break in the Saito until I finish my current Somethin Extra build.
Any ideas, or pics would be great.
Thanks in advance.
Thanks in advance.
RE: 72 Saito on Pulse XT???
G''day Mate,
Turn the carby around, so the needle valve is on top, then the throttle will be lower, & easier to hook up.
You could use a steel push rod, bent in a "U" shape with a ball link on the end of it, to hook up your throttle.
Have a look here, lots of info, http://saito-engines.info/index.html
