battery size
Reply
Old 04-14-2008, 07:01 PM
1rcaddict
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default battery size
Can anyone tell me the proper flight battery size to power 3 Hitec HS-5645MG servos, 2 JR DS821 servos and 1 Hitec HS-81. I keep having trouble with my larger aircraft glitching. Right now i''m using 2 Sanyo 6 volt 2000mah wired in parallel.
1rcaddict is offline
Old 04-14-2008, 07:27 PM
Nathan King
Nathan King's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: battery size
Well, according to my calculations you should have at least 3850 mAh of current. Right now you have 4000 mAh. I don''t see a problem. [sm=confused.gif]
Forgive me for asking such a stupid question, but how did the range checks go?
Nathan King is offline
Old 04-15-2008, 08:16 AM
1rcaddict
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had 2 successful 8 minute flights prior to the glitch. Could a stalled servo have exceeded the current output of the battery? I don''t know what the "c" rating is on the Sanyo 2000mah.
Old 04-15-2008, 09:16 AM
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The C rating has to do with how fast the batteries can be discharged. Each C is equal to the capacity of the pack. A 1000mah 1C battery could be discharged at 1000mah a 2c at 2000mah. That is over generalized but gives you a basic idea.
As far as powering a rx and servos, especially running 2 packs, I dont think you are overloading the packs C rating.
Gringo Flyer is offline
Old 04-15-2008, 12:09 PM
Flying freak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kinda aircraft? any chance some off the servos are binding? a servo that binds can pull killer amps
Flying freak is offline
Old 04-15-2008, 02:57 PM
Gringo Flyer
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are the packs draining down fast? How many flights are you getting on a flight?
If its glitching I would try a different switch, do another range check with engine running and without, try unplugging servos one by one, etc. You need to try to isolate what is causing the glitching so you can pick it.
My hunch is that its not the packs unless there is a loose solder joint. But the fact that you are running in parallel would mean both packs would have to be bad which is very unlikely.
