stuck bearing
Reply
Old 04-15-2008, 01:06 PM
NOSFRK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default stuck bearing
I have an evolution 46 that the bearings have went bad in. The front bearing came out eazy, the back one is stuck. Any ideas on an eazy way to get it out? It does not have a lip from the front side of the bearing to drive it out by. any ideas would help. I was thinking of heating it up but dont want to damage the case.
NOSFRK
NOSFRK is offline
Old 04-15-2008, 01:18 PM
Nathan King
Nathan King's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: stuck bearing
Heat the case up in the oven (with everything else removed of course) until it''s good and warm. Then hit the engine on a board (front facing up) until the bearing falls out (shouldn''t take much).
Nathan King is offline
Old 04-15-2008, 01:24 PM
spiral_72
spiral_72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was going to say a heat gun. The aluminum block will absorb heat much faster than the SS bearing. The bore should increase in diameter by a couple thousands and you can push it out.
spiral_72 is offline
Old 04-15-2008, 02:07 PM
Kelsey_B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can find complete instructions here
[link=http://www.rc-bearings.com/]RC Bearings.com[/link]
Kelsey_B is offline
Old 04-15-2008, 04:34 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I drop my cases in A pot of boiling water to get the bearings out. I made up A hooked tool from landing gear wire to just pull out the rear bearing. Easy
Gray Beard is offline
Old 04-15-2008, 05:45 PM
NOSFRK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the good advice, and quick replys. the bearing came right out. I had a 4 stroke that did the same thing, dang near beat it to death getting the bearings out. THANKS again guys!!!!!
NOSFRK
NOSFRK is offline
