Reload this Page >
Hanger 9 Pawnee 40
Hanger 9 Pawnee 40
Old 04-17-2008, 06:32 PM
gtnkick
My Feedback: (7)
Default Hanger 9 Pawnee 40
I recently purchased the new Hanger 9 Pawnee 40. It recommended the Saito 82, I have plane all put together and balancing it is a bit of a prob. Battery placed back as far as possible in the fuse. When setting plane on the Great Planes balancer it still is looking for 5ozs of weight on the tail. Does anyone have a better idea/
Old 04-17-2008, 07:54 PM
fozjared
Default RE: Hanger 9 Pawnee 40
any way to fit a shorter engine mount on that plane?
Old 04-17-2008, 09:00 PM
ChuckW
ChuckW's Avatar
This seems to be common on the Pawnee. There is a thread on the plane in the ARF forum. On mine, I removed some covering from the bottom of the fuse and installed a second receiver battery toward the tail along with a second switch under the hatch. Once I laid down a new piece of Ultracoat, you'd never know I did anything. The second battery not only corrected the CG, it also gave me a redundant power source and switch if. If one were to ever fail, there is a back-up, not to mention the increased mAh capacity (i.e.: more flights before recharging). The plane has such a big, flat wing that it doesn't really notice the extra weight.
Old 04-17-2008, 09:02 PM
ChuckW
ChuckW's Avatar
ORIGINAL: fozjared
4-strokes usually have the carb and intake tube on the rear of the cylinder so you can't always move them closer to the firewall. Also, the Pawnee has a cowl so you need clearance for the spinner.
Here's mine:
Old 04-18-2008, 01:38 PM
gtnkick
My Feedback: (7)
Will try your suggestions and thanks. Approx. how much weight was added to the tail/
Old 04-19-2008, 04:52 PM
ChuckW
ChuckW's Avatar
I used a 1100mAh battery that I think weighed around 4.1 ounces. There is plenty of room in the rear of the fuselage. I made a light ply bracket that glued in between the fuse sides and braced it with some tri-stock. Then I just wrapped the battery in foam and zip tied it to the bracket. A couple spare servo extensions gave me enough wire length to mount the second switch under the hatch.
