Saito 65 Prop Size Question
Reply
Old 04-18-2008, 07:29 AM
roryschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Saito 65 Prop Size Question
I bought a used cub (simular to a Goldberg aniversery Cub). It has a used Saito 65. I read the Saito website and it recommends a 13X6 prop. I tried it and can't get the plane to climb. I tried a 11x6 and the results are even worse. It floats along about 20ft off the ground. With the 13x6 I got it approx 40 ft off the ground. When I try and climb it stalls.
I have checked the RPM of the motor and it runs full throttle at 8200rpm consistantly. I would have expected to be able to gain altitude at 1/2 that rpm.
Any thoughts would be appreciated. The airplane and motor came from an older gentleman who has flown this plane a lot. Could it be the motor is just wore out ??
roryschmidt is offline
Old 04-18-2008, 08:15 AM
Nathan King
Nathan King's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito 65 Prop Size Question
You should be getting MUCH more than 8200 from an 11x6. In fact, an 11x6 is so small (too small) that you should be over revving the engine. I'm getting mid 9000's with a 12x8. Remove the rocker cover and check valve clearances with a thickness gauge. I set mine to three thousandths of an inch. Since you are flying a Cub use a large diameter prop with a smaller pitch while keeping the prop load consistent. I had a 65 on a 81" wingspan cub, and it pulled that thing around well at half throttle.
Nathan King is offline
Old 04-18-2008, 09:45 AM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As Nathan said, check the valve clearance. You should be turning about 10,500 - 11,000 with a 13x6 prop. My Saito 72 will turn 11,000 - 11,300 with a 13x6 prop (I have it adjusted for 10,800 so as not to over rev the engine)
Campy is offline
Old 04-18-2008, 09:55 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
13x6 APC is the prop to use if in a sport airplane or warbird like the Kyosho
Kawasaki Hein.
A 14x4W APC could perhaps be used in a slow flying model .
The fuel you should use is 10-15% nitro and the glow plug OS F!
Tank should be 8oz-10oz (240-300cc).
jaka is offline
Old 04-18-2008, 06:14 PM
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used a 14-6 MA on my .65 since I got it. It will turn about 9000 rpm, right at the torque peak. No need to rev a 4-stroke to redline.
khodges is offline
Old 04-21-2008, 08:03 AM
roryschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the feedback. I did set the valves this weekend. They we out by perhaps a thou. I have another cub with a Saito 65 and it works fantastic. I can take off at 1/2 throttle with a 13x6.
Has anyone ever had one rebuilt at the factory?
Old 04-21-2008, 01:37 PM
Nathan King
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: roryschmidt
Yes, you should be able to get off at half throttle. That's what I always did with my 1/5 cub - it was nice and gentle, very scale looking.
Old 05-01-2008, 02:33 PM
jay2000dakota
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a 65 in my 40 size aeronca champ with a 12-6, its probly in the 9500. I can take off at half throttle and scale flight is at about a 1/4 and with the show struts off it'll pylon race with the best of them. Im no expert but I'd think valves could be out of adjustment or there could my fuel restriction somewere in the carb, fuel lines or the tank.
jay2000dakota is offline
