Reload this Page >
NiCAD RX Battery…Can you have too much mah?
Reply
Old 04-19-2008, 01:42 AM
dive2277
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NiCAD RX Battery…Can you have too much mah?
RX NiCAD Battery…Can you have too much mah?
I'm looking for the right size RX flight battery... I have a spare 1000 mah 4.8v JR battery and with my NexStar w/ 6 Futuba 3004's and 2.4Ghz fast RX I can make 6 12-15 min flights. I'm will be using 7 3004's and the same 2.4Ghz RX in my BH Models T-28 Trojan and I was thinking of:
4.8V, 1700mah Flat NiCAD Battery using Sanyo cells:
Length: 2.63”
Height: .675”
Width: 2”
Weight: 4.6 oz.
Can I go with a higher mah 4.8V, 2000mah Flat NiMH Battery using Panasonic cells?
Length: 2.63”
Height: .68”
Width: 1.72”
Weight: 4.7 oz.
God Bless and many Happy Landings,
Stuart (dive2277)
dive2277 is offline
Old 04-19-2008, 01:59 AM
ErikElvis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NiCAD RX Battery…Can you have too much mah?
You can never have too much mah! What will get ya is you may need a new charger to charge the NiMH properly. You prob wouldnt want a stock charger that charges at 100mah. I just bought some 4.8V 2300mah NiMH batts to replace he nexstar factory batts. Got them from ebay. all-batteries I believe.
ErikElvis is offline
Old 04-19-2008, 03:49 AM
dive2277
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, that’s what I was hoping to hear... What's a good fast charger that can charge my RX and TX at the same time?
Stuart
dive2277 is offline
Old 04-19-2008, 03:59 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dive2277
Stuart
Keep in mind that some transmitters have a fuse in them to protect the electonics. And those fuses are chosen somewhat based on the charge rate of the issue battery. So fast charging might not work perfectly with every TX.
And there aren't many intelligent chargers that do different voltage/amp at the same time. AccuCycle Elite does. And works off AC or DC.
da Rock is offline
