charge jack on Hitech and futaba
RE: charge jack on Hitech and futaba
It is not wise to use the Futaba connector on the Hitec. The Futaba uses a 5mmOD 2.1mmID (Radio shack part no. RS274-1567) while the Hitec uses a 5.5mm OD 3.5mm ID (Radio Shack no. RS274-1573) connector. You could buy the proper connector from RS and solder it in parallel with the existing connector on your Futaba charger and charge either safely with the same charger.
My Feedback: (7)
ORIGINAL: Rodney
IN
WOW
I never knew this, and I've been using a futaba wall charger on a hytec optec 6 for three years.
Too late to quit now.
Matt
Matt
My Feedback: (7)
ORIGINAL: Matt14x
WOW
Matt
WOW
Matt
I can use the futaba charger to charge both Hi-tech and Futaba radios, but I cant use the Hitech male plug to fit the radio plug on a Futaba?
