Reload this Page >
Some questions....
Some questions....
Old 04-21-2008, 07:11 PM
Pete737
Pete737's Avatar
Default Some questions....
Went to maiden y P-47 yesterday but on TO power the flaps inadvertently deploy. I am running an airtronics 2.4 system. I was led to believe that this omitted any possibility of interference so I placed the RX directly behind the ignition unit as it was ergonomically convenient. My flap servos are Hietec mighty minis (analog) the rest are digital. I thought that this in itself was a problem but was reassured that the airtronics RX could handle it. Today I have moved the RX back about 10 " away fro the ignition and engine, I have yet to test it. Just wanted to know what you think. Also my G-26 ei began to sputter when given gas yesterday. Not tuning issue, tried to blow down the carb but soe kind of check prevented it. Last night took it apart and cleaned it thouroughly. Just curious if anyone knew of any other possible causes for this, Including the most likely.
Zenoah G-26ei
Airtronics RDS8000 2.4 on 6 volt system
Thanks and best regards. Peter
Old 04-21-2008, 07:24 PM
Nathan King
Nathan King's Avatar
Default RE: Some questions....
Did it pass an idling range check?
Old 04-21-2008, 07:44 PM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Pete737,
2.4 Ghz systems aren't "immune" from interference. What they are is they won't interfer with each other when they are on like old 72 Mhz systems were. They are still radio devices and are subject to RF interference in the same manner as older radios were. The same precautions that are taken with an electronic ignition system need to be followed when you are using 2.4 Ghz radios as well.
Ken
Old 04-22-2008, 06:37 AM
Pete737
Pete737's Avatar
Yes sir the range check was golden. I have yet to test with the new setup, I will let you know how it turns out.
Oh yeah, Is it me or do you have to have a mechanical engineering degree to install the retracts on the H9-150 P 47.....
Pete
Old 04-22-2008, 09:06 AM
Stew99
Did you abort the takeoff or did you continue to fly with no problems? With the rx placed right behind the engine it's possible that big chunk of metal blocked the signal at some point in the TO run.
Old 04-22-2008, 10:25 AM
Pete737
Pete737's Avatar
"A big chunk of metal"? Would you ind explaining that please?
Peter
Old 04-22-2008, 10:36 AM
RCKen
My Feedback: (9)
RCKen's Avatar
The "big chunk of metal" he is referring to would be the engine. 2.4 Ghz radios are more prone to having their signals blocked than the older 72 Mhz radios did because of the shorter wavelength of the 2.4 radios. This is why all of the 2.4 Ghz receivers have 2 (or more) receiving elements, with the theory being that if one element is blocked the other one can still receive signal. With this in mind 2.4 receivers, and their antennas, need to have a little thought put in to where they are mounted in a plane. They shouldn't be placed directly next to any large metal obects such as the engine, muffler, langing gear, or such. Care also needs to be taken when mounting next to carbon fiber parts as these can shield the antennas as well. If you placed your reciever directly behind the engine of your plane it's entirely possible that the metal of the engine blocked signal from the receiver, which could have caused your problems.
Ken
Old 04-22-2008, 04:36 PM
Pete737
Pete737's Avatar
ok. Would a metal pushrod to the throttle be a posible problem?
Old 04-22-2008, 04:54 PM
carlosponti
carlosponti's Avatar
2.4 from what i read in my futaba manual also have problems with carbon fiber and certain composite materials. transmitting through carbon fiber was listed as something to be aware of.
