SPEKTRUM AR6200 bind issue
FL
OK, here goes. I recently have began testing the 2.4 technology world hoping to switch over. Got a DM9 module for my XP9303 and I am using a Parkzone Stryker as my test vehicle with a AR6200 receiver. The issue is when binding the RX to the TX everything is great both receiver and satelite get a solid light and work the controls fine. Then next time I power up (TX then RX) only the satelite receiver gets a solid light. The main 6200 blinks forever Unless I rebind. Bad receiver or dumb pilot? BTW when powering down I do (RX then TX).
RE: SPEKTRUM AR6200 bind issue
G'day Mate,
I know this will sound silly, but, you must remove the bind plug after you have rebinded the RX.
I assume you have done this, but I have found, that is the only way any of my RX's lights keep flashing, is if I don't remove the bind plug.
TX
the only time i lost bind was when i switched the rx on first, but i have heard some issues with people laying the tx down or leaning it against something that depresses the bind button in the rear when pressure was applied to flip the switch on... that may be something to watch for.
FL
Yes, I do remove the bind plug after both RX establish links. However next time I power up only the satelite locks a link and the main 6200 RX keeps flashing. The reason I discovered this is because I was getting lock outs almost after every turn. I was able to land and then discovered the flashing light on the 6200. I did NOT notice if both RX lights were solid before take off.
AL
I've lost two airplanes with Spectrum wiyh loss of bind in the air.One time it came unbound when I touched the engine with a glow driver.I am not going to trust it anymore on my big gas planes until I find out what's going on. I talked to horizon and they want me to send the radio to them since it happened on 3 different rec.
Sounds to me like you have the newer software in the main receiver and not the satalite. The flashing is telling you that you lost power or experienced a brown out. If you turn it off for a few minutes then turn it back on it should be on solid but if thats the case they should both be flashing. They have free firmware updates and it sounds like yours needs it.
FL
Thanks to all for your support. I beleive I found the problem. I changed the esc to a different one and had 3 flights without incident. Hope it stays like that. The "BAD" esc still seems to work fine on 72mhz as I put two flights on it with my mini edge. 2.4 technology is certainly picky when it comes to voltage flow, receiver location, and older equipment. Both systems have pros and cons I guess. The way I see it is - APPLES and ORANGES. Some people will say 2.4 is the best thing since sliced bread, and I do too after spending 400.00 to experiment. At the end niether system to date guarantees your bird will go back home with you 100%. Its just another system.
Is it because the esc and motor are causing a voltage drop (brown out)? I would suggest powering the radio with it's own power source and see if that ends your problem.
