securing lead weights
Reply
Old 04-23-2008, 04:39 PM
indgroove
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default securing lead weights
Hello, I have a SIG Kadet. I used 2 strips of lead weights to get the plane balanced.
Occassionally, the weights work loose from the plane.
Any reccomendations for securing the lead to the plane?
Ind
indgroove is offline
Old 04-23-2008, 04:44 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: securing lead weights
clean with alcohol
then epoxy the lead directly
da Rock is offline
Old 04-23-2008, 05:39 PM
BillyGoat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just had the same dilemma and ended up using hot glue. Only two flights on the plane but so far so good
BillyGoat is offline
Old 04-23-2008, 06:34 PM
My Feedback: (17)
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use ¼” round lead cut to the length I need. I drill a clean ¼” hole in the fuselage, wing tip, etc and epoxy the lead inside. Make sure the lead is below the drill hole and cover with a piece of MonoKote.
8178 is offline
