DA50 TOP END TUNING
Reply
Old 04-28-2008, 04:48 PM
borgie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DA50 TOP END TUNING
Hi, I have run aprox a gallon of fuel though my engine. on the 1st flight, half way through at max power the engine almost quit. Do i need to richen the top end as when this engine was run on the ground it was perfect with good low to hight end transittion.
any help would be appreciated.
Thank you
borgie is offline
Old 04-28-2008, 09:01 PM
6.5x284tony
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DA50 TOP END TUNING
Hey Borgie,
With the plane on a bench and well secured, let the engine come up to operating temperature. Make sure you have someone securing the plane. Open the throttle to wide open and then adjust the high end needle out (rich) untill you notice a significant drop in rpm. Start turning the needle in untill you reach the highest rpm, and then back it back out untill you notice a drop of about 200 rpm. I would personally run two gallons of break-in fuel before you start going too lean though.
6.5x284tony is offline
Old 04-29-2008, 02:33 AM
borgie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks tony guessed this was solution but did not know exact way to acheive it at least i dont need to worry about dead stick know thanks again borgie
borgie is offline
