Identify this maneuver
SC
This is very, very cool. I didn't even know this was possible. Any idea what they call it?
http://www.metacafe.com/watch/125069..._above_ground/
RE: Identify this maneuver
ORIGINAL: victorzamora
It's called a showpass. That's all it is.
My Feedback: (22)
I"m not up on the airshow lingo, but to me, it looked about half Knife edge and half slip. But he did it very low and fairly slow, which makes it an impressive specatacle and fairly dangerous.
Most airshow stunts are all about showmanship and aren't comprised of very difficult elements. But they are flown low and with precision, so they are still very impressive.
SC
Is it an illusion? because I'm not seeing what provides the lift!? It's not hanging on the prop, and it doesn't look like it's moving fast enough to provide any lift from the ummmm, well, something. I'm in awe.
Tried to Google show pass, showpass, and some variations. I didn't really see anything so I'm not sure how it done yet.
My Feedback: (27)
OH
THe maneuver requires a plane with a good thrust to weight ratio, a rearward C.G. and a huge rudder. At cruise speed, the nose is brought up to about 45*. Then, the plane is rolled to a 45* bank. Next the rudder and ailerons are cross controlled to put the plane in a slip. Throttle is used to control altitude and all of the flight controls are used to maintain attitude.
My Feedback: (9)
ORIGINAL: firstplaceaviator
JUst an uncoordinated Airshow Pass with a Yak 55.... Looked good!
My Feedback: (27)
OH
Looks to be a SU26. Prop running clockwise and too sleek to be a YAK.
Doug
ORIGINAL: spiral_72
It's really an exeraggerated slip by a plane with a big rudder and a lot of power. I would think that most all full scale pilots have done a slip, but probably not to that extreme.
I taught them as a T-37 instructor pilot back in the 1960s. We used the wing low slip for crosswind landings and slips during a Simulated Flame Out (SFO) landing. The SFOs spooked many students, so I prepared mine for them. I remember saying, "All right Lieutenant, when the check pilot has you fly to the aux field at 10,000 feet altitude, you know he'll ask for an SFO next. Be ready." I would tell them to circle down and aim for the middle of the runway so they wouldn't be short. My ulterior motive was to make them have to slip. Students that know how to slip and can nail the SFO, get better grades on the whole check flight. If they screwed up the SFO at the first of the flight, they were mentally shot for the rest of the check. I told them to stand on the rudder, full rudder and just steer the plane to the runway. They ended up in a pretty steep bank, standing on the wing tip, so to speak, but that seemed to impress the check pilot that they could handle the plane. My students always got good grades from the check pilots. Four years instructing and never had a student wash out.
That was their 30-hour check. Take off, SFO at aux field, go to acro area and do lazy-8, Chandelle, Immelmann, loop, Cuban-8, cloverleaf, aileron roll, barrel roll. Then climb up and do a spin and recovery. Next, it was back to the pattern for a single engine landing, a no-flap landing and a regular landing. Man, that was 40 years ago that I taught that. I sort of lost the original question. Sorry.
My Feedback: (27)
OH
Heres a great video of a Stearman bipe doing the same thing! (Just a little less bank[)])
http://www.youtube.com/watch?v=BiAIDMuuzPY
My Feedback: (-1)
Ed, thank you for joining in. At one time this stunt was shown on RCU vids but got pulled off for some reason? It was the Russian team flying at A show, much better too I might add. It turned me on so much I went out and tried to learn it. Nothing I owned would even come close so I scratch built A Sukhoi 29 80 incher that was supposed to be powered by A 1.20 four stroke. I built it around A Brison 40cc gasser so it was light and over powered. I could almost get it to do it but I thought I needed A bigger rudder. I will never know, soon after I moved here I took off and forgot to pull out that long silver thing in the center of my radio.
The maneuver is called a "forward slip" and performed in a manner greatly exaggerated from the same maneuver used in general aviation. The maneuver quality depicted in the video shows that you have a very skilled pilot and that he knows his aircraft extremely well. Any well trained commercial rated pilot should be able to perform the maneuver to a high performance level, but below the level of that shown.
