Wheel Pants
Wheel Pants
I have an ARF that just test flew over the weekend very well the problem is that on its very first flight after landing I noticed the wheel pants were loose on both sides. What can I do in order to keep them tight?
The ARF is the AW 540T Edge 90 size built by World Models. The pants are held on by a screw that threads into the fiberglass.
Blackie
Blackie
My Feedback: (12)
Wheelpaints
I ran into that problem with one of mine and I put blind nuts behind the plywood plate that the screws go into...I also put a drop of thin glue on the threads when screwing them into the blindnunts to keep them from backing out...hope this helps...Gerry
