Great planes superskybolt engine question
Reply
Old 05-10-2008, 10:03 PM
dispatcher418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Great planes superskybolt engine question
Hello All,
I have a GP super skybolt arf. I am thinking of putting a fore stroke in it. I am looking for some input,
should I go with the os fs 91
or a saito 91?
any help would be great.
thanks mike
dispatcher418 is offline
Old 05-10-2008, 10:42 PM
mirwin
mirwin's Avatar
Default RE: Great planes superskybolt engine question
Mike,
Mine is the kit, which builds heavier than the ARF, and I have an O.S. FS-1.20 Surpass w/Pump in it. I wouldn't consider a smaller engine for the kit. However, a friend of mine bought the ARF, and he put a Saito 1.00 in it which hauls it around fairly well.
Although the manual calls for a .70 - .91 4-stroke, I think you may be disappointed with the performance. The Skybolt is a super aerobat and you'll want some power to get the most enjoyment out of it.
Besides, they're very tailheavy. I have nearly 14 ounces of lead forward of the firewall even with the big OS 1.20 and a sub-C NiMH receiver pack immeditely behind the firewall. So you might as well put a slightly heavier engine in it to avoid having to put too much useless lead in the nose.
I'd go for a 1.00 - 1.20 4-stroke if it was my plane.
Mike
mirwin is offline
Old 05-11-2008, 06:30 AM
dispatcher418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awsome thanks.
this is my first afr, i have always built kits...i felt weird about buying it.
Old 05-11-2008, 07:15 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Consider adding a layer of decent plywood on the firewall. It is only two layers of LitePly and almost completely unsupported on the top 1/4. Only has the sheeted foam of the fuselage up there.
It doesn't have to be thick, just thick enough. 1/16" works well.
da Rock is offline
Old 05-11-2008, 08:03 AM
dispatcher418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great Thanks
Old 05-11-2008, 02:25 PM
Jester241
Jester241's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our field instructor has one with a .91 OS surpass and it looks to fly great,but I've never actually flown it myself. He sure makes it fly nice anyway.
Jester241 is offline
Old 05-11-2008, 03:15 PM
pkevinb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the Skybolt ARF with the OS .91 Surpass on the front and has all the power I want. If I were to do it again I would probably go with the Saito to save a little weight. I balanced my plane according to the manual but it was extremely nose heavy and I eventually removed all the weight I added to the nose.
It's a great flying plane, in fact my favorite.
pkevinb is offline
Old 05-11-2008, 03:29 PM
dispatcher418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ill probabally go with the saito
Old 05-11-2008, 07:02 PM
RCPtero
RCPtero's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a kit in the box still and have purchased a Saito 1.25 to put in her.
Tom
RCPtero is offline
Old 09-25-2012, 06:25 PM
trs3243
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the same plane,gp superskybolt arf.I have had one years befors with a ys 110. it flew wonderful and fast. this one has a dle 20 gas engine. with 2 batterys in the nose it is nuteral at cg.this engine is new/3 hrs running time.it will pull 12 lbs thrust with a 15/8 prop 9740 rpm or 12 lbs with a 15/8 vess 8720 rpm. 8lbs 8 oz auw.it flies good.i only fly gas and have 3 other dle engines. the covering on this arf is not the guality i expected from gp. the construction was fine but the covering sucks big time.
trs3243 is offline
Old 09-25-2012, 06:43 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the kit building forum there is a thread called Show us Your Bolts and you can see a lot of them and see what engines they are using. Just do a search. Some ARFs in the thread too but mostly kits.
Gray Beard is offline
Old 09-27-2012, 10:29 AM
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an OS 61 SF in my Skybolt ARF and it flies great. For a four stroke the OS 95V four stroke would really go nice in that plane. I have the 95V in a Revolver 70 and GP P-47 and it has lots of pulling power with a APC 14x7 prop.
Bruce
landeck is offline
Old 09-29-2012, 08:47 PM
DGrant
DGrant's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's an "All things SuperSkyBolt ARF" thread... alot of info here...
http://www.rcuniverse.com/forum/m_42...tm.htm#4236365
Read up on it.. its one nice plane. I've got one sittting here waiting to put together. I bought an OS 1.10 for it a while back... put that in another plane and I like it so much in that.. I contemplated buying another 1.10 ... instead bought the OS 95V... and I've yet to run that engine.. but my SkyBolt is getting one or the other... I can't imagine this bipe with anything but a 4-stroke.
DGrant is offline
Old 10-01-2012, 01:36 AM
charlie1960
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Skybolt arf with a Saito 100 and 14/8 MA prop.
A picture (video) is worth a thosand words....
Its a nearly perfect combination, and a really fun plane to fly.
http://www.youtube.com/watch?v=wk5Ks...&feature=g-upl
charlie1960 is offline
Old 10-01-2012, 07:08 AM
delateurj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got one with a ys 1.10 and its a rocket with that power plant.
I think any .90 to 120 four stroke makes a good pairing.
- Joe.
delateurj is offline
Old 10-01-2012, 10:21 AM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: delateurj
- Joe.
That would be my first choice too but I have a couple of them on hand. I would also use one of my OS .91s, I have a couple of them too. At the field the OS .91 seems to be the most popular choices.
Old 10-01-2012, 10:39 AM
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the ARF I have an OS 61 SF; it is the engine the origianal GP Skybolt was designed for. It provides more than enough power with an APC 12x7 prop and flies it very well including verticle performance.
Bruce
landeck is offline
