Engine shock mounts
Reply
Old 05-14-2008, 11:59 AM
Penuts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine shock mounts
I have a Sukhoi 31 68", useing a S.P.E.C 26CC
There's nothing wrong with the engine however im getting vibration and would like to dampen it down some, are there any shock mounts for that engine? I cant seem to find any.
Or any suggestion would be appreciate, My prop and spinner are balanced,this is my first gas plane,maybe im just overcautious.
Penuts is offline
Old 05-15-2008, 06:44 PM
Hurri
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine shock mounts
all of my gas engines have rubber mounts even have the G26 with them . saves a lot of vibration thru the F/wall & airframe & also the radio . Basically I put a piece of 3/16 alum plate
on the back of eng rear of the muffler , bolted to the eng; the plate is aprox 4" sq on the G26 & has 4 rubber s a pair on each corner -total 8 rubbers , a 1/4 " or 6 mm bolt goes thru the rubbers into blind nuts in the f/wall . lock wire is connected thru the bolts to make sure they don't loosen .
Hurri is offline
Old 05-16-2008, 03:13 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Penuts
http://www.jtecrc.com/giantmounts.htm
iron eagel is offline
Old 05-18-2008, 07:04 PM
Penuts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys,I'll look into that and see what i can come up with.
Thanks again
Penuts is offline
