soaking engines in antifreeze
Reply
Old 05-15-2008, 02:44 PM
Tbone4life
Tbone4life's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default soaking engines in antifreeze
I've seen and heard of soaking nitro engines (disasembled) in automotive anti-freeze to clean them up.
Has anyone actually tried it and what were the results?
I soaked mine in it all nite and it seems no cleaner than before?
Tbone4life is offline
Old 05-15-2008, 03:02 PM
carlosponti
carlosponti's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: soaking engines in antifreeze
i think you have to boil them in antifreeze. also might mention that antifreeze is dangerous so dont reuse the pot you use to boil the engines in.
carlosponti is offline
Old 05-15-2008, 03:05 PM
Villa
Villa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The antifreeze must be heated. I cleaned two of my engines using an old electric crock pot; heated them overnight. A little brushing under running water and they were bright as new. I now use fuel with synthetic oil to keep them clean of burned oil.
Villa is offline
Old 05-15-2008, 03:10 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You put it in a crock pot on low, no boiling.
Very effective but you need to remember a couple of things.
1. The fumes are bad.
2. Porcelin is porous, don't ever cook food it again. I used a 5 dollar one that I picked up at a garage sale.
3. The new environmentally friendly antifreeze won't do anything. You need the cheap, plain ole etheleneglycol green stuff.
It works like a champ
BarracudaHockey is offline
Old 05-15-2008, 03:48 PM
Tbone4life
Tbone4life's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, add heat. Got that.
Since my first post I've sprayed it with easy off oven cleaner[:@]
It's clean, just discolored almost black now? will the antifreeze bring back the original color?
Old 05-15-2008, 04:19 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Tbone4life
Nope, the surface has been etched by the caustic stuff in the oven cleaner.
And if you get any inside the carb, into the exhaust, or the bearings, you got "trouble in River City".
There does happen to be a safe sprayon cleaner you can get in grocery stores. And it works in the Kitchen. It's DAWN Power Dissolver. It works and doesn't etch what it contacts. You still don't want to get it into those holes.
da Rock is offline
Old 05-15-2008, 09:44 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just what Baracuda said, I run A bit more heat though. At one of my old clubs one of the guys bought the 5 buck crock pot and A number of us tried it. Works great. I left mine in for A couple of days and A tooth brush worked to clean off the gunk.
Gray Beard is offline
Old 05-16-2008, 06:55 AM
rwright142
rwright142's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never done the crock pot method or an engine, but I did what da_Rock said, "Dawn Power Dissolver" on a muffler and documented it here: [link=http://www.rcuniverse.com/forum/m_5929584/tm.htm]Removing Glow Fuel Residue[/link]
It took a whole 10 minutes and that included taking the pictures and typing the post.
Before and after pictures:
ID:	950359   Click image for larger version
rwright142 is offline
Old 05-16-2008, 07:55 AM
PoormansACE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BarracudaHockey
This guy is right! ive done this with great sucess! depending on how dirty your motor is, you can even get 2-3 runs with the antifreese.
BE WARNED!!! THIS PROCESS WILL REMOVE POWDERCOAT!!
Ask me how i know! it worked so well on my O.S. and my TTiger, I gave it a go With my Irvine .46 and took every last bit of that pretty red paint off!![X(]
PoormansACE is offline
Old 05-16-2008, 11:37 AM
rctrax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im am not intersted in the muffler i'd like to see what it does to the engine
rctrax is offline
Old 05-16-2008, 08:01 PM
sledge_78
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RCTRAX,
I've done both the heated antifreese and t6he dawn Power disolver. The antifreese does work. The Power disolver works fster and better. You can find it in Walmart. Try it, you won't be dissapointed.
Sledge_78
sledge_78 is offline
Old 05-17-2008, 08:41 AM
BillyGoat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had one O.S. discolor with Antifreeze, every other engine I’ve done has turned out looking brand spankn’ new. In another forum, I think Tips and Techniques, there was a suggestion to use a polish like Brasso to remove discoloring. Might want to do a search and give it a try to remove the discoloring.
BillyGoat is offline
Old 05-17-2008, 10:31 AM
Champ-RCU
My Feedback: (132)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When using antifreeze don't put in any parts that have plastic parts that can be deteriorated by petoleum oil products, such as the YS and OS engines with pumps and regulators.
MTY
Champ-RCU is offline
Old 05-17-2008, 01:01 PM
pmw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, I've been told that the anti-freeze can harm the glow plug elelment. I've done a couple of engines with good results, but I always removed the glow plug, so I don't know about the element being affected. Remember, the engine will be very hot when you remove it. Don't just stick your hand into the pot. Use tongs or wrap a wire thru the mounting holes that you can use to pull the engine out.
Paul
pmw is offline
Old 05-17-2008, 05:59 PM
KF4TH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello guy s have you tried the old Clarence Lee method of Cascade dish washer detergent,it works ongrease and grime pretty good.It wont get the varnish from the castor off .
KF4TH is offline
Old 05-17-2008, 06:40 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glow plugs, plastic?? The engines should be stripped, taken apart, bearings removed. This is just to remove the burnt on varnish and oil from the case before A rebuild.
Old 05-18-2008, 05:18 PM
Champ-RCU
My Feedback: (132)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Grey Beard,
Couldn't agree with you more. However, some will plunk all the parts into the soup and come out with broken bits. Also at times you can get an engine that can't be taken apart. You don't want to hear that story. In fact I'm trying to forget it myself.
MTY
Old 09-13-2008, 10:24 PM
BUGGS50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what happens if you put the whole engine in , muffler still on it . totally under the anti freeze
BUGGS50 is offline
Old 09-14-2008, 06:10 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BUGGS50
Do you have a crockpot that large?
If you do, you'll get everything clean all at the same time.
da Rock is offline
Old 09-14-2008, 06:20 AM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what happens. The dirt is removed from the outside of the engine by the antifreeze cleaning procedure and floats around as little black bits of grit. Logic dictates that the dirt is also removed from the inside of the engine and likewise floats around inside the engine. If this stuff is not cleaned out it possibly will get in lodged the bearings, between the piston and sleeve, under the ring etc,etc,
Take the engine apart.
Ed S
Ed Smith is offline
