Mounting FMA Copilot
FL
I am in the process of mounting an FMA COPILOT on the underside of the left wing of an Advance 40 and am a bit leery of using sticky back velcro cause sooner or later oil will get to it.
Does anyone have any suggestions ?
Thanks Varmit
Thanks Varmit
FL
Jerry:
The plane that I am installing the Copilot on is a low wing and has a rather large canopy which might obstruct the view of the sensor.
Varmit
Varmit
FL
Jerry:
The plane in question is an advance 40 by Thunder Tiger. I have already installed the Copilot on the wing but reinstalling it under the fuse sounds good cause then I wouldn't have to plug and unplug the cable everytime the wing is removed.
The FMA people suggest installing it directly behind the canopy on top of the fuse......but this spot has a very sharp radius and I don't think that it would be stable enough.....I guess that I could make up a bracket of somekind with a flat spot on top and match the radius on the bottom.
Are you using a switch or a knob on your TX to control the unit(I have a Hitec Eclipse) and plan on using the flap knob for control
of channel 6.
If you have any suggestions about anything concerning the Copilot I sure will listen.
Varmit
of channel 6.
Varmit
