OS 20 FP Fuel consumption
I want to use an OS 20FP in a small model.
Only tank size that fits realy comfortably is a 2 oz size.
Anyone have an estimate how long it can be expected to run on this (assuming some full and some partial throttle)?
(a 5-6 min. flight time is quite acceptable for me)
PA
RE: OS 20 FP Fuel consumption
I think you will need a bigger tank. I am limited to a 2oz. tank with an OS.15LA on one model and I must set the timer to 4min. 30 seconds and land immediately when the buzzer sounds. Otherwise I risk a deadstick situation.
I'm referring to a sport scale bipe - Gordon Whitehead's Hawker Demon.
Gordon used a .19 with a 2 oz tank, but does not mention how much time he got out of it.
It's a lightly loaded model, that wil probably cruise around on part throttle most of the time.
ORIGINAL: Dsegal
Also, is your vent pipe reaching right up into that "bubble" at the top of the tank?
I'll probably bench run the engine with the same tank just to check operating time.
