Lipo battery in transmitter
Hey guys im looking into putting an lipo battery into my 6EX and i just wanted to know if anyone else as done this to their own transmitter yet and i just want to know what you think about it and if its worth the money
My Feedback: (16)
SC
RE: Lipo battery in transmitter
ORIGINAL: Jackedman
ORIGINAL: fancman
I don't see how it would be worth the money unless you fly for five hours a day and have ten airplanes programed into your transmitter. I have a friend who did the same thing. He typically flies three of four flights each visit to the flying field. When I askes why he spent 150.00 to upgrade his transmitter battery he said it was to get more flying time. Go figure!!!
ORIGINAL: Jackedman
KS
I put a 11.1v 2500mah in my RDS8000 for $40 plus shipping and it works fine. I've read we're some Radios, and I'm thinking it might have been the Spectrum radios, don't work well with them.
AZ
I would look at a big NiMh first.
LiPo will cause your voltage alarm to no longer function.. the LiPo would be 3s2p 11.1V, typically, so by the time it drops to 8.8 or whatever your alarm is set at it is WAY too late. You have to watch your voltage on your TX display carefully.
Been there done it. Lipo works great, but I still think I would rather have my alarm working properly.
My Feedback: (17)
CA
Yep, just watch the voltage. 9.5 volts should be fine as a low point, but since the radio will run forever, just throw it on the charger after a day's flights and be ready for the next day or weekend.
CA
It is also recommended you DON'T charge the battery in the transmitter.
That sounds like a lot of extra work to me.
Aftermarket replacements in NiCd or NiMh are about $20.
Good Luck,
KW_Counter
Good Luck,
KW_Counter
AZ
ORIGINAL: Dorsal
I know it ain't Duralite, cause that's what I have. Your "no-fly" voltage should be whatever the manufacturer says it should be. TX batts are nothing to take chances with...
From Duralite:
11.1 Volt Li-ion Packs reading off Transmitter
Stop Fly
—10.8 volts
Fully charged
—no load - 12.4 - 12.6 range
http://duralitebatteries.com/flight/tech-ion.php
