Midwest Super Stinker
Brison 3.2...pretty heavy stuff
Mine has a Moki 1.8 and is exactly 13lbs.
I figure with an OS1.60 I could bring it down to 11.5 pounds. Then all around performance would be much better and the vertical would be fantastic. That includes removing the tail weight, using a nylon/glass motor mount, and changing the ABS pieces for glass pieces. It flies quite nicely at 13 pounds, at 11.5 it would be much nicer.
