6 volt battery question
My Feedback: (18)
RE: 6 volt battery question
That depends on the capacity (mah) of the pack and what you are putting it it. A 6v battery wont last as long as a comparable 4.8 pack but its not a lot of difference.
A 1000mah 4.8v pack on 3d plane with high torque digital servos will not last as long as a 500mah 6v pack on a trainer with standard servos.
Its in a hanger 9 spitfire standered servos 3004 got a seperate 4.8 for retracts, I believe the 6volt is a 1600 mah I flew 3 times and it was on 6.40 I believe still said it was good, I'am thinking that probley I could go to 6.20 or so
My Feedback: (13)
If you stop flying when the loaded voltage drops to 6.2 volts you will be very safe. In fact you have probably only used about 10 or 20 percent of the capacity.
Here's what a typical 5-cell NiMh discharge looks like:
My Feedback: (18)
With that setup you will have a full day of flying on that pack. Its still a good idea to check the voltage after every couple flights. I generally check between every flight.
Normal discharge on a NiMH pack should be around 1.1 volts per cell. With a 5 cell (6 volt nominal) call it quits around 5.5-5.6 volts per cell and you should be good to go. Your setup is probably drawing between 300 and 500 ma during regular flight, which means you have 1600 mah/500 ma = 3 hours of flying time. Assuming 10 minute flights (normal average flight) thats 18 flights. With refueling between flights, thats about 4 flights per hour, which means 4 1/2 hours at the field of continuous flying. Thats a lot of flying!
Brad
Brad
ORIGINAL: bkdavy
Brad
Brad
The less you draw the pack down in a normal cycle the longer it will last.
At 6.4 volts, you still have 90% of your charge left, a perfectly normal occurance after a few short flights. You can safely fly down to 5.6 volts. Take a close look at DMcQuinn's graph, it is pretty typical. You will note that the voltage quickly falls to 6.4 volts then holds well above 5.5 volts for a long time. Get a Voltwatch (you can get them for 5 cell batteries) and it will warn you as when, at the end of a flight, it falls into the yellow it is time to charge. IMHO a Voltwatch is better than a loaded voltmeter as it is always connected and easy to immediately access the charge level at the end of each flight before turning off the switches.
