Run time equation?
Run time equation?
is there a way too figure out how much fuel per minute you will use while in flight? I know there are variables involved but im talking about an average of half throtlle. Lets say for examples sake how long will a .15 run on a 4 oz. tank????
NC
lets see...
Seems that I heard somewhere that fuel consumption for 2-stroke glows on average is 1 oz / minute per .40 cu in.
So for your example:
.40 cu in / .15 cu in * 4 oz = 10.67 minutes at full throttle
I have no idea how accurate this is for smaller IC engines but it seems to be a fairly reasonable (gu)estimate for the .40 to .91
sized stuff.
Also, did some factoring based on some observed data from from my own engines. The reasonable factor I came up with is 250.
So .15 cu in / 4 oz * 250 = 9.375 minutes at full throttle
But as you already stated, there are so many variables.
Cheers.
James
sized stuff.
Cheers.
James
Run time equation?
Many variables, eg revs, flying style, prop size, mixture setting, engine condition etc
You will also find that some engines are more economical than others, I find my Irvine 46 guzzles fuel (6cc lasts 7-8mins), and is less econimical than a larger OS91 (16cc lasts 25-30mins).
After spending sometime with an engine, you'll get to know it's performance and if you have a computerized radio set, you can dial in timer settings for each model.
Cheers,
Chris
Cheers,
Chris
