ARG: E-flight's pitts m12
UT
[:@] AARRGG!!!: on the new pitts m12, the control conectors between the upper & lower ailerons
is way too fragile "plywoodwood" just trying to get the retainer clip on ( about the size of an adam ) I busted the plywood ( sobbs ) I'll post my fabricated repair LOL
UT
RE: ARG: E-flight's pitts m12
I used a 1' micro control horn and shaved it down to look similar to the original plywood horn, looked like a tadpoll drilled a 1/6" hole directly through the original plywood / 5 minute epoxy & i'm back in buisness.
