Redo paint on yellow arrow on F18C
CA
Gentlemen,
I am finally getting around to fixing the arrow on the bottom of my JL F18 and was wondering how to prep it. As you can see from the picture, the factory painted the entire doors yellow. I need to repaint part of the doors blue. I know the paint will probably not match but it will be better than what it is now. I will be using a spray can of Blue Angel Model Master Paint.
My question is should I just paint over the existing paint or should I rough it up with something like 400 grit sandpaper or remove the existing paint altogether and start from scratch.
Since I have very little knowledge when it comes to painting, I would really appreciate any advice.
Thanks for your help,
Wayne
Wayne
RE: Redo paint on yellow arrow on F18C
since you're painting a dark color on top of a lighter color..I'd rough it up with sandpaper...clean it with alcohol..tape it off with that new green tape it's called turtle tape I think..great for painting won't let the paint seep under the edge...and use very light coats
CA
Thanks jetmech05, you are the greatest. I posted this in the jet forum on 10/30 and didn't get any responses. I should have put it in this forum to begin with.
Thanks again, I appreciate and will take your advise.
Wayne
Wayne
