funtana s 40 control throws
Reply
Old 11-06-2008, 11:59 AM
bigblockbones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default funtana s 40 control throws
Hi does anyone know the control throws for the funtana s 40? A frend gave me the plane after i returned my tiger to kit form. I have no manual and cant seem to find this info on line.are they the same as the funtana s 50? thanks in advance.One more question.I am running a evo 52nx for power cant afford new motor any sugestions on prop size? thanks again.
bigblockbones is offline
Old 11-06-2008, 12:35 PM
JoeAirPort
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: funtana s 40 control throws
10-15 degrees on low rates for elevators and ailerons. 25 degrees for rudder. The control surfaces are huge on this thing. I had two of them.
3D rates, all you can get on all surfaces.
Try a 12-6 prop.
JoeAirPort is offline
Old 11-06-2008, 01:49 PM
bigblockbones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks joe.
Old 11-06-2008, 06:19 PM
tunes079
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The manual is downloadable on horizons web site.
tunes079 is offline
Old 11-07-2008, 08:27 AM
kbailey45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what the manual says I use these rates and they work out good but at least its a great starting point. I didnt worry with having the up and down on the ailerons different I just used the 3/4" for low and 2 1/8" for high. Also if you need it the CG is 5 5/16"-5 11/16". For 3D you will probably have to a little further back than the recommended CG but its always good to start in the middle. You may also want to go a little further with your ailerons on high rates mine are at about 2" up and down and it almost takes full aileron to keep it from torque rolling in a hover.
LOW
AIL-3/4" up 5/8" down
ELEV-7/8" up and down
RUD-2" up and down
HIGH
AIL-2 1/8" up 1 7/8" down
ELEV-2 5/8" up and down
RUD-3 7/8" up and down
kbailey45 is offline
Old 11-07-2008, 10:24 AM
bigblockbones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info,I did find the manual on the horizon web site.Im going to try it out this weaknd.Thanks again.
Reply
Display Modes
